It is currently Sat Jan 20, 2018 4:11 am
Post new topic Reply to topic  [ 4 posts ]
 new LSx springs
Post new LSx springs
impressive if true.... i love engineering.
http://www.ls1tech.com/forums/new-produ ... g-kit.html
Sat Apr 25, 2009 3:08 pm
Post Re: new LSx springs
impressive is right!
Sat Apr 25, 2009 3:14 pm
So let's see..
The guys running cams and valves big enough to need springs like this won't buy them, because they've invested enough $$ in their engine that "budget", springs don't appeal to them. They need the best, not the best priced.
The guys running smaller cam's don't need them (and shouldn't run them, despite what TSP will tell them - more is not better!).
So who is their target audience?
Also, WTF does a dyno sheet on an engine show you with nothing to compare it to? That they're stable to 7,000rpm? whooptee-freakin do. My "lowly" PAC beehives are stables to 7k, too. Glenn's motor would make more power than that on an engine dyno, too.
At least these won't sag in 10-15k miles like the patriots do. Speaking of which, TSP claim these are the most durable springs on the market and didn't even test any springs directly from PAC... One of the few companies who actually MAKE springs.
Here's some good reading. http://www.hardcorels1.com/vbulletin/sh ... php?t=2875
Sat Apr 25, 2009 9:34 pm
Eskimo wrote:
So let's see..
you're right, i wouldn't buy a "budget" spring for my motor, even if they would work in my application. i'm running over 600lb open pressure, 1.220 installed height. i'd like to see those things not float valves on mine @ 7500 rpm. :grin
Only springs I'll buy...
PSI CT1043XL
> Dual 1.580"
> 235lbs@1.950
> 600lbs@1.250
Killer valve spring for a guy on a budget running a "man's cam" though :lmao4
2001 WS6 Trans-Am M6 421 w/ Solid Roller Mans Cam, 608rwhp / 496rwtq
2002 2500HD CCSB Duramax/Allison, 580rwhp / 1052 rwtq
2015 GMC Yukon Denali 6.2L
2008 Honda 450ER Limited, 65rwhp/39rwtq
2010 Polaris Sportsman 850 XP EPS
2014 Polaris RZR 1000
Sun Apr 26, 2009 6:27 am
