It is currently Tue Oct 17, 2017 2:48 am
Post new topic Reply to topic  [ 6 posts ]
 A/C idler tensioner pullies
Post A/C idler tensioner pullies
hey guys what's up this past weekend I set out to change those annoying birds under my hood....the tensioner replace great but the idler killed me with that stinking t50. I had a half inch breaker bar on it but I all I did was break off one of the star tips could not break loose. I did not try heating it up yet. I was debating welding the bit to the bolt to break but wanted to see what you guys suggested first
Eric
02 matte black z m6
2013 java metallic altima SV
Wed Apr 16, 2014 5:32 am
Post Re: A/C idler tensioner pullies
Cover it with PB blaster and let it sit over night. See if you can get a hand impact driver and bits that fit at sears or somewhere. Sometime a little hammer help goes a long way. Be careful heating it, there is LOTS of aluminum there. I personally would not.
Wed Apr 16, 2014 6:14 pm
Ohhh OK so no heat gotcha.... hmmm a couple guys told me bout that trick it just might work I'll try when I get free time again. It doesn't chirp as bad since changing the tensioner so I got time
Eric
02 matte black z m6
Wed Apr 16, 2014 6:27 pm
You can use heat sparingly if you want, my personal preference is not to use a torch on Aluminum at all. Normally vibration is just as effective
Wed Apr 16, 2014 6:34 pm
Also make sure if it doesn't come completely loose you work it back and forth, if you keep going in one direction the odds of breaking something go up astronomically
Wed Apr 16, 2014 6:35 pm
hahaha I hear you there man I'm a machinist so I know a lot about broken bolts / taps / drill bitsthanks for the advice good advice now I gotta figure out another problem I have when my lights are off I'm pulling 4 amps of parasitic draw so I think one of my headlight relays may be bad just gotta find out which one
Eric
02 matte black z m6
Thu Apr 17, 2014 3:28 pm
