It is currently Sun Feb 25, 2018 2:21 am
Post new topic Reply to topic  [ 9 posts ]
 my rear is leaking
Post my rear is leaking
Now that that's out of the way, whats the best way to clean it, and the underside of the car? simple green and a bunch of rags? i'll be putting a new gasket on the diff cover and replacing the pinion seal when i change whats left of the fluid.
Tue Jun 02, 2015 8:24 pm
Post Re: my rear is leaking
:lmao4
Any good industrial degreaser should do the trick. Simple Green is fine and I'm personally on an Adam's APC kick right now.
Wed Jun 03, 2015 8:39 am
Get the heavy stuff with something like simple green, then I usually grab a wax/grease remover to hit the fine stuff, and then I always paint!
Wed Jun 03, 2015 6:08 pm
what are you using to paint? something eastwood i'm guessing?
on that topic, What should i use to paint the stock A Arms? im going to sand blast them at work, and install new bushings and ball joints. Was thinking rattle can black rustoleum.
Sun Jun 07, 2015 7:18 pm
Eastwood Extreme Chassis Black!
Sun Jun 07, 2015 8:09 pm
another vote for Eastwood extreme chassis black. covers great and holds up to harsh fluids like brake fluid.
Tom
Sun Jun 07, 2015 9:29 pm
Yup, eastwood rust encapsulator, then extreme chassis black on top of it
Mon Jun 08, 2015 5:01 pm
They also make a product called chassis kleen, that does a spectacular job at removing grease and dirt, but use it in a well ventilated area if you get it.
Mon Jun 08, 2015 5:03 pm
http://www.carbrite.com/products/Exteri ... Hot-Stuff/
Wed Jun 10, 2015 1:16 pm
