It is currently Sat Jan 20, 2018 4:06 am
Post new topic Reply to topic  [ 11 posts ]
 Noobie
Post Noobie
Heard about the site a lot from Nick(Batman) figured I would come on here. I was on here before but it was a long time ago and a lot has changed.
Heres some info on the car:
84TA406's 1984 Pontiac Trans Am
Engine:
-406ci SBC
-Quick Fuel Technology Q750 carb, -6AN fuel line, Jegs fuel PSI gauge
-Edelbrock Victor Jr. manifold
-World Products Sportsman II heads, ported and polished, 10* locks and retainers, Comp cams Springs, pushrod guides, seats. ARP 7/16" rocker studs, fully setup for a roller cam
-Custom grind Comp cams retrofit Hydraulic roller camshaft .593/.570 lift 238*/248* duration @.050 113LSA
-Comp cams Pro Magnum lifters
-Comp cams Pro Magnum Pushrods
-Comp cams Pro Magnum Roller rockers 1.52
-509 casting block (rarest 400 block)
-Cast pistons,rods, crank
-HEI distributor
-MSD supercomp plug wires
-MSD Digital 6 box
Exhaust:
-Hooker Longtube headers/ceramic coated
Drivetrain:
-TH400, J.W. Ultra-Bell, TCI Trans shield, TCI 4200rpm converter, RMVB, B&M deep pan
-Hurst Quarter stick shifter
-Custom length driveshaft for TH400 swap
-GM 7.5" 10 bolt rearend with 3.73's (Saving for a 9" now!)
-Full disk brakes
Suspension:
-Stock struts(front)
-Competition Engineering 3 way adjustable shock(rear)
-Moroso trick springs in the front
-UMI Lower Control Arms
-Spohn tubular trans crossmember
Misc. other stuff:
-Edelbrock electric fuel pump #1791 and relay kit #1795
-BG fuel filter
-Mallory 3 port return regulator
-Powermaster XS torque mini starter(required for LT's)
-RECARO rear seats
-Dual Gauge A pillar pod.
--Sunpro Water temp gauge
--Sunpro Oil PSI gauge
-Pioneer 4X6 IN-dash speakers
-Autometer 3 3/8" tach
-A/C delete heater box
-Electric fan
-Custom switch panel
-Permancool Maxi cool trans cooler and fan
-Dual oil filter relocation kit
-Innovate LM1 Wideband/Datalogger
Still a work in progress...
Sun Jan 03, 2010 9:14 am
Post Re: Noobie
Nice TA! Welcome...
Sun Jan 03, 2010 9:35 am
Post Re: Noobie
While we generally don't allow folks here that admit to knowing Nick. We'll make an exception since a 406 in a third gen is just cool. Welcome!
Sun Jan 03, 2010 9:41 am
Post Re: Noobie
haha he cant be thats bad... lol
The 406 is a pretty good motor, nice mild build nothing too crazy for now. Had some issues this past year but now that I have a GOOD job it's al getting worked out.
Sun Jan 03, 2010 9:58 am
Post Re: Noobie
Welcome, and nice combo!!
Stumps Garage Inc.
Dynojet 224xlc chassis dyno
www.stumpsgarage.com
ryan@stumpsgarage.com
03 Cobra 569hp 699tq
Sun Jan 03, 2010 10:42 am
Post Re: Noobie
Welcome aboard!
Sun Jan 03, 2010 12:36 pm
Post Re: Noobie
Nice 3rd gen! Welcome :greetings10
Sun Jan 03, 2010 2:02 pm
Post Re: Noobie
:greetings10
Sun Jan 03, 2010 2:24 pm
Post Re: Noobie
welcome aboard Josh!
Sun Jan 03, 2010 3:11 pm
Post Re: Noobie
:cheers
Sun Jan 03, 2010 5:18 pm
Post Re: Noobie
:thumb
1996 Camaro SS - Just some bolt ons
2013 Subaru Legacy Sport - afraid to void the warranty!
1977 Chevy K10 - just starting on this heep
Sun Jan 03, 2010 11:36 pm
