It is currently Mon Aug 21, 2017 5:27 am
Post new topic Reply to topic  [ 1 post ]
 Orion HP2400 2-Channel Amp
Post Orion HP2400 2-Channel Amp
$70
RMS @ 4 Ohm: 2 x 85, RMS @ 2 Ohm: 2 x 130, RMS @ 4 Ohm: 1 x 225, Variable low-pass 50Hz to 500Hz, variable high-pass from 50Hz to 500kHz, 16dB of boost with INTELLi Bass, Fuse size: (2) 15 ATC, Dimentions: 7.0" x 10.2" x 2.4", Power Rating: 85 Watts RMS x 2 at 4 ohms, Signal to Noise Ratio: -77dBA (reference 1 watt into 4 ohms), Massive loosely-regulated MOSFET power supply, All new pure MOSFET output stage design, Intelli-Bass Equalization Circuit and Remote Gain Option, Heavy Gauge Direct-wire High Current Power and Speaker Terminals, 12dB/octave High- and Low-pass Filter
Fri Nov 07, 2014 9:24 am
