It is currently Sat Jun 24, 2017 10:27 am
Post new topic Reply to topic  [ 1 post ]
 93 LT1 drive train.
Post 93 LT1 drive train.
Stock 93LT1 engine with approx 110K, harness, EMC and trans (700R4). Only thing I would do is change the trans governor. When hot lapping the shifts could get sloppy.
This engine runs strong. no smoke, very good oil pressure. With 2:73 gears it ran consistent 13.80s. We didn’t push it hard since it was a first year bracket racer. (16 year old). So now stepping up to a more aggressive set up.
The EMC has a mild tune: Raised Rev limited, added timing (premium fuel only), high fan comes in at 190. I did the tune, so if someone needs it changed I will do it or just pull the carrier and return to the stock tune.
Can work out local delivery.
Asking $1,450.
http://allentown.craigslist.org/pts/4776471727.html
Fri Nov 28, 2014 9:42 am
