It is currently Thu Dec 14, 2017 3:47 pm
Post new topic Reply to topic  [ 6 posts ]
 98-02 brake backing plates
Post 98-02 brake backing plates
Looking for a set of 98-02 brake backing plates - need both sides, calipers too if you have them.
Tue Sep 13, 2016 8:04 pm
Post Re: 98-02 brake backing plates
When do you need them by? I'm going to grab a 10 bolt here soon to clean up for the Hawk, can try and get one with the brakes on it.
Wed Sep 14, 2016 4:42 pm
sooner the better? in the process of a 4 corner 4th gen brake upgrade, front spindles are out for modification, so I'll have the fronts wrapped up in 2 weeks. i can always delay the rear upgrade to over the winter if need be. Brake line failed to the passenger front caliper post flush (first one in over 14 years) taking out the caliper, rotor, pads, bearing, and ball joint. rotor was molten red after the 1.5 mile test drive. decided to just update the whole system instead of throwing money at a stock update.
Wed Sep 14, 2016 7:34 pm
Gotcha, I'm not going to have the time to go hunting until late October. I'll get one with brakes and see if you still need them.
Fri Sep 16, 2016 7:00 pm
got a set of backing plates from a guy on tech. You might want to get a rear with them anyway, they are a discontinued part, and just the backing plates are going for $150-$160 shipped.
Sat Sep 17, 2016 7:23 pm
I bought an axle that has everything, won't be picking it up till Oct 24th, but if you are still in need lmk
Sat Sep 24, 2016 4:34 pm
