It is currently Sat Aug 19, 2017 9:06 pm
Post new topic Reply to topic  [ 5 posts ]
 I think I found the guys the designed the Optispark!
Post I think I found the guys the designed the Optispark!
ONLY the same morons that decided to put a distributor under the engine, could design a truck and put the &^*#(^?>! ABS unit under the cab!
WHO DOES THIS?????
:banghead
93Z M6 Black:
The 385 LT1 - Supercharged, 3-core front mount intercooler, stage II heads, 3:73's, Street twin clutch, Jethot Longtubes, Mufflex 4" catback, Tuned by me! S+W cage, Spohn Suspenion, Yada Yada Yada
1) Build it
2) Race it
3) Break it
4) Repeat!!!
Tue Apr 11, 2017 7:25 pm
Post Re: I think I found the guys the designed the Optispark!
They have been under the cab pretty much since their inception. What are you messing with the block for?
Tue Apr 11, 2017 8:25 pm
2005 Silverado with 180K
Brake line rusted and split. The other weren't so pretty, so I bought the whole set.
There is no room to turn the wrench a decent amount. I have to use two wrenches that have different angle/offsets.
Have to take a bunch of OTHER RUSTED crap off as well, Have to lifting/tilt the cab off the body mounts to replace the lines.
No wonder they say the deals charge up to $1,500
But it happened in my drive way! VERY thankful for that!
LOL! selling the Z because I don't want to do this type of work, and I'm busting my butt on this little project. - BAD CARMA! :gripe
93Z M6 Black:
1) Build it
2) Race it
3) Break it
4) Repeat!!!
Wed Apr 12, 2017 6:21 pm
whoa, selling the car?!? :shock: :shakehead
Sun Apr 23, 2017 7:18 am
The brake lines rusted and popped on my 2003 Silverado. Unfortunately, it happened on a boat ramp 75 miles from home with the boat in tow! I bought a pre-bent stainless kit, but I took it to Diehl's in Danville to have them install. There was much swearing involved and they ultimately ended up taking the entire bed off to run the lines into the frame rails. They said it would have been easier to make the lines from a roll. Then, the next day, I traded the truck in. Between labor and the cost of the kit, I had around $800 into the repair.
Fri Apr 28, 2017 6:28 am
Users browsing this forum: No registered users and 2 guests
